Mk1 Fiesta Brake Caliper Rattle
4 replies to this topic
#1 Craig89
Craig89
  • 600 posts
Posted 14 May 2013 - 05:26 PM
After recently refurbing and fitting mk1 fiesta calipers to my mini I have noticed that the sliding caliper really rattles about in the carrier when driving along. A bit of brake pressure and it takes up the slack and it's fine. There are wedges fitted top and bottom between the caliper and carrier, held in by a split pin and it's these that seem too loose causing the caliper to be loose.
Does anybody have experience of this, or have I not fitted them correctly?
Thanks, Craig
#2 petey81
petey81
  • 1,333 posts
Posted 14 May 2013 - 05:47 PM
are the split pins tight?
http://www.theminifo...rd-fiesta-bits/
 this link might help, I have mk2 fiesta calipers and the carriers support wire was bent causing it to shake.
#3 Craig89
Craig89
  • 600 posts
Posted 14 May 2013 - 07:24 PM
I have fitted the biggest split pins I could get in there but it didn't make much difference really. It could be something to do with the wire pieces, they may support the wedges somehow
#4 petey81
petey81
  • 1,333 posts
Posted 14 May 2013 - 07:33 PM
Yeah true I did see a post a while back but couldn't find it earlier. Google it you might have better luck.
#5 Craig89
Craig89
  • 600 posts
Posted 19 May 2013 - 03:30 PM
Just an update, I sorted this out. The wire pieces push the caliper against the carrier with the wedges there to close up the gap. My gap was too big causing the rattle so i needed to remove the wire from the carrier and bend them in a way to push the caliper closer to the carrier. Hope that makes sense
