Re Torqueing Head After Gasket Change
5 replies to this topic
#1 marsy
marsy
  • 374 posts
Posted 15 May 2013 - 06:54 PM
After changing head gasket, and after first heat cycle, people are saying re torque the head,
My question is, do i do it in any specific order?
#2 rob963
rob963
  • Just Joined
  • 350 posts
Posted 15 May 2013 - 07:00 PM
Yes, it should be done in the same order as when first torquing the head down after changing the gasket I believe so anyway and even if you don't have to, I would any way just to be safe :-)
I think I am right there, if not, hopefully someone more qualified will be along shortly :-P
Hope that helps,
Rob
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 15 May 2013 - 07:05 PM
Yes definitely do it to the same order as tightening.  You aren't slackening all the nuts and then tightening them all, if you do that you will release the head.  You slacken and retighten each one in turn so it stays tight.
#4 marsy
marsy
  • 374 posts
Posted 15 May 2013 - 08:42 PM
Ok many thanks!
#5 jaydee
jaydee
  • 8,565 posts
Posted 15 May 2013 - 08:46 PM
And of course wait till it cool down!
#6 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 16 May 2013 - 07:04 AM
Do the tappetts need re-checking after re-torquing?
