Well I've had a busy winter and my car is now back on 4 wheels and driving with practically all new suspension components..
Took it down the road and its knocking and squeaking a little from the suspension back and front! (its had all new cones and Hilo's fitted with new knuckles new dampers on the back in a brand new sub-frame).
All together tightly and the wheel bearings are good. The radius arms are tight and not moving.
My thoughts are:
The squeaking, is the new cones. I hope this will stop in time.
There are a couple of knocks from front and back. Has anyone had trouble with their Hilo's knocking?
Reading what I can find online it's quite likely to be the damper not being tight enough.
How tight should I do them?
and should I have washers on the damper bolts like this. " Washer - Damper - Washer - Bolt "
Doing my head in as i need to send it for an MOT soon! Want to get driving my beast.
