Hi,
My project has ground to a bit of a halt at the moment due to financial reasons so I am using my time to get some of the parts refurbished.
I have started on the brake master cylinder and clutch master cylinder.
My question is how far can they be stripped?
They are both red raw with rust and the pistons have seized up but im confident they can be refurbished still.
So far I have started to strip the clutch cylinder and have removed the circlip and push rod and freed up the piston which now operates perfectly but does the piston come out? if so how?
Next I want to start on the brake master but I need to know the best method of removing the reservoir tank. I can see that there is a roll pin to remove and then the tank pops off the rubber seals but what is the best method of removing the pin as it needs to come out the opposite way from the only way to get a hammer and drift at it.
The brake master is a yellow tag item and the clutch master is a lockhead one, oh and the car is an 84 model.
Any help on this would be truly appreciated.
Ben
