Brakes. What Brakes.
6 replies to this topic
#1 bluecooper95
bluecooper95
  • 48 posts
Posted 17 May 2013 - 09:50 PM
I have this slightly worrying problem with my brakes. Every now and againg the brake pedal feels a little too spongy for my liking. And there has been to occasions where i have pressed the brake and the pedal has gone to the floor and the car has not slowed down at all. But if i pump the brake pedal, It firms up and normal brake is resumed. I noticed this a couple of weeks ago, but i swear it is happening more often now.
Any ideas
cheers
Elliott
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,094 posts
  • Name: Neil
Posted 17 May 2013 - 09:52 PM
Change the brake fluid then bleed the brakes first and see how that goes.
#3 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 17 May 2013 - 09:55 PM
and check for fluid on the inside of your rear wheels when left overnight, your rear cylinders could be leaking
Edited by Rob Mac, 17 May 2013 - 09:56 PM.
#4 sonikk4
sonikk4
  • 16,094 posts
  • Name: Neil
Posted 17 May 2013 - 09:58 PM
Have you had to top up the fluid level at all??
#5 bluecooper95
bluecooper95
  • 48 posts
Posted 19 May 2013 - 11:29 PM
the brake fluid is at max. i dont know when the fluid was last changed though. there seems to be no leak.
#6 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 21 May 2013 - 12:14 PM
Master cylinder leaking?
#7 brivinci
brivinci
  • 1,211 posts
Posted 21 May 2013 - 11:50 PM
Might sound strange but how are ur wheel bearing up front? If they are worn, it could be letting the brake disk go out of round and push the brake pistons back in. That in turn pushed fluid back into the master so you assume you don't have a leak or anything like that. It actually happened to be but it was my drive shaft nut that came loose (it didn't have a cotter pin in it). I made a sharp turn, the wheels and disk got all out of round and then I had no brakes until I pumped a few times
