Valve Stem Oil Seals
13 replies to this topic
#1 bikenutmart
bikenutmart
  • 579 posts
Posted 18 May 2013 - 04:30 PM
Hi, Im rebuilding the head on my 998 A+ engine(99H) code and am not sure if i should put seals on all the valve stems, i do have 8 of them, they were only on the inlets on stripdown, but have been told to put them on all the valves by several poeople, is this correct? im sure someone on here will know the answer. Cheers Martin.
#2 racingbob
racingbob
  • 3,061 posts
Posted 18 May 2013 - 04:44 PM
i was told put them on inlets
but on the exhaust put them on but take off the little spring thing
this was from a top engine builder builds mini 7 engines
#3 bikenutmart
bikenutmart
  • 579 posts
Posted 18 May 2013 - 05:25 PM
Cheers Bob.
#4 mini=love
mini=love
  • 211 posts
Posted 18 May 2013 - 08:44 PM
Iv never bothered with exhaust, but if yo have them it cant harm to stick them on
#5 mm man
mm man
  • 405 posts
Posted 18 May 2013 - 08:57 PM
Why? Remove the springs
#6 Gremlin
Gremlin
  • 2,142 posts
Posted 18 May 2013 - 09:46 PM
Advantages-
Limits oil being burnt
Disadvantages-
Stops valve stems being lubricated against stems
Could increase wear as it does not let the valve go where it wants
#7 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 18 May 2013 - 10:01 PM
Even rover couldn't decide if it was a good idea to fit them to exhausts, some came with some without
#8 grahama
grahama
  • 2,442 posts
Posted 19 May 2013 - 07:03 AM
I think it was standard to fit them to all stems after a certain date,  put them on all mine when I rebuilt.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 May 2013 - 07:51 AM
  They started to be fitted to all of them as emissions laws got tighter.
#10 mini13
mini13
  • 3,811 posts
Posted 19 May 2013 - 09:35 AM
also use the mpi ones as they take the exhaust temp better.
#11 bikenutmart
bikenutmart
  • 579 posts
Posted 19 May 2013 - 10:15 AM
Wow !!! So many replies, as ive got 8 i may as well use them, Thanks again everyone. Martin.
#12 mm man
mm man
  • 405 posts
Posted 19 May 2013 - 06:50 PM
I have just rebuilt my head (89 mg metro 4 seals from standard ) and fitted all 8 as this seems to be the way forward now a days but just wondering why remove the springs on the exhaust seals ?
I get the reason why to fit the seals but the spring removal only on the exhaust ???
Does any one have any ideas as Bob was told this by a mini race engine builder but he doesn't know the reason why ???
#13 scott_65_cooper_s
scott_65_cooper_s
  • 104 posts
  • Local Club: open to suggestions
Posted 19 May 2013 - 07:01 PM
One disadvantage of leaving them off is that oil can run down when the car is parked, giving the classic ploom of smoke on start up.
#14 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 20 May 2013 - 11:00 PM
The reason he's  been advised to leave the small spring tensioner off the exhaust valve stem seals is to allow better lubrication of the valve stems by allowing some oil to pass. The exhaust valves run hotter than the inlets & lack of lubrication could cause them to seize. Not so much of an issue on a basic road motor, where the springs can be left on, but on a race engine or Turbo motor it certainly is.
As said the later MPI stem seals are superior.
Phil.
Edited by Turbo Phil, 20 May 2013 - 11:04 PM.
