My standard 998, it seems to bubble and pop quite a lot is this normal, also you can see my freshly painted gold wheels
Posted 18 May 2013 - 05:07 PM
Posted 18 May 2013 - 06:32 PM
It doesn't sound that bad, the fuel/ air mixture is probably a little rich now the temperature is rising and that is would cause the lift of pop.
Posted 18 May 2013 - 07:24 PM
Ah thanks for that I think it makes it sound nicer, but I was worried that it was bad.
Posted 18 May 2013 - 08:28 PM
I also like the sound of a slight rich running engine. However keep checking your spark plugs to make sure they aren't sutting up. Remember light brown is the perfect colour for a spark plug, otherwise you may end up with a misfire if the plugs are too sutty
Posted 18 May 2013 - 08:48 PM
Posted 05 June 2013 - 03:52 PM
Sorry for the late reply. Brown/Tan is good as long as its light. Any thing darker would suggest carbon build up.
http://www.apriliafo...37&d=1341312352
Try the link
Which one best describes your spark plugs ?
Posted 07 June 2013 - 09:27 PM
Try the link
something like 8 so doesn't look that bad
Posted 07 June 2013 - 10:48 PM
Posted 10 June 2013 - 10:46 AM
I would lean out the mixture a little. Maybe get a colourtune kit. It definitely helped me get my fueling right.
