A Few Issues With The Mini Again.
39 replies to this topic
#16 ToM 2012
ToM 2012
  • 4,066 posts
Posted 18 May 2013 - 08:25 PM
ballast is what you put in the bottom of a boat to stop it floating so high in the water. lol
lol ino ballast for using for concrete but whats it on the engine? i am going to change the alternator in the morning can i pop to yours and lend your electric tester?
#17 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 May 2013 - 03:26 PM
hi all i have changed the alternator to my old one what worked. but itsputting out 12.57 volts when engine is turning over no change when the engine is of. but i checked the other mini that we have and that is 14.23 volts when on tick over. so there has got to be something wrong somewhere i am thinking now was my alternator ok but something on the wiring is throwing it out so its not recharging? is there anything else i can check before i go and buy a new one with a higher volt. would appreciate your thought?
#18 alicetheauto
alicetheauto
  • 1,222 posts
  • Local Club: Rusty Nuts Minis, Leicester
Posted 19 May 2013 - 04:06 PM
It should be 13.5v or more. Any less and it won't charge the battery.
#19 alicetheauto
alicetheauto
  • 1,222 posts
Posted 19 May 2013 - 04:07 PM
Also, ballasted ignition systems were fitted to some early-mid 80s minis as a resistance wire to drop the power needed to give a spark.
#20 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 May 2013 - 04:19 PM
thanks for that mine is the 1991 model mini how do ino if its ballasted or not? is there a special type of alternator i need or are the alternators all the same? thanks tom
#21 waddle
waddle
  • 536 posts
Posted 19 May 2013 - 04:41 PM
mine started spluttering under load,  rebuilt the carb and it was fine, i did adjust timing at the same time ,but im prety sure it was due to the under fueling when loaded
ps, you do have some ignition issues so i would sort them before looking at the carb
Edited by waddle, 19 May 2013 - 04:42 PM.
#22 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 May 2013 - 04:51 PM
drove it today tho and it hasnt splutterd since. drives lovely to be honest so not to worried about that now what would you look for if the alternator was ok? could it be something else that stops the power going to the battery?
#23 waddle
waddle
  • 536 posts
Posted 19 May 2013 - 04:55 PM
id turn the ignition on , make sure everything if off , like headlights etc,  then get the multimeeter on everything to see if your loosing current anywhere just to check you dont have a drain on it anywhere
#24 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 May 2013 - 05:02 PM
ile try that tomoz but what i dont get is i put the new battery on yesterday i have been starting and turning it off and done all that driving today and the volts are still the same on the battery i would of thought if it was not charging the battery then it would of drained some power out the battery by now? what i am thinking is if i buy a high output alternator put that on see if it brings it up to 13-14 volts on tick over and it should be fine? could it of been the first battery they sold me was a bad one. or is that rare to come by. many thanks tom
#25 waddle
waddle
  • 536 posts
Posted 19 May 2013 - 05:14 PM
not sure if duff batterys are common or not, but if you take it to quickfit they do free battery tests :)
#26 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 May 2013 - 05:17 PM
ok cheers waddle
#27 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 19 May 2013 - 05:54 PM
as you have been for a good run in it today, and you havnt called me to say its packed up, i think your alternator must be working well enough!
even on a brand new battery you wont get hours of running without the engine dying.
as the meter was reading the same on your brand new alternator as the reading given by your old one, i think its safe to say its not your alternator. it seems highly unlikely they are both slightly duff.
how many times did you switch the engine off today and fire it up again while you were out for a drive?
#28 ToM 2012
ToM 2012
  • 4,066 posts
Posted 19 May 2013 - 06:20 PM
just added them up and around 11 times today and i was thinking the same the power out of the bettery would of been under 12 volts correct me if i am wrong? man i want this mini done just want to drive it and not think about isit going to make it to the shop and back haha
#29 alicetheauto
alicetheauto
  • 1,222 posts
Posted 19 May 2013 - 10:47 PM
The alternator is the same. The ignition coil is different, and there is a different wire running to the distributor. I think it's white/pink (its been 8 years since I had a ballasted ignition car...) check the Haynes book of lies.
#30 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
Posted 19 May 2013 - 11:33 PM
if you started it up that many times, and managed a run to stourport i think its safe to assume its charging!
