No. There are A series 1275s with tappet chest covers, but no A+ ones. It's a Gold Seal (oddly with a Silver Seal head fitted), what engine number does it carry?
It could just have been painted gold and silver mind
Posted 18 May 2013 - 09:06 PM
Posted 18 May 2013 - 09:18 PM
If it is a Gold Seal, the engine number isn't anything to do with the standard numbering system, which is why I asked.
Posted 18 May 2013 - 09:19 PM
It's a 1275, don't worry. Probably a non Mini sourced block. One of those new photos makes it obvious (2 core plugs on the rear end of the engine). To be honest the small, A series water pump pulley and A series head in the first photo made it quite likely, but I don't know enough about old blocks to have known for certain from a photo of the back of one.
And they are HS2s.
Edited by Dan, 18 May 2013 - 09:23 PM.
Posted 18 May 2013 - 09:20 PM
Posted 18 May 2013 - 09:21 PM
Posted 18 May 2013 - 09:25 PM
See above.
Gold Seal engines were Unipart reconditioned service replacements, very high quality rebuilds. And painted gold.
Posted 18 May 2013 - 09:29 PM
Posted 18 May 2013 - 09:30 PM
I would have said this:
Like I did up there ^^ !
Posted 18 May 2013 - 09:33 PM
Posted 18 May 2013 - 09:40 PM
Wait, stop. Apparently I'm not the brightest today either. The engine in the second set of photos is a different unit from the one in the first photo you posted. The engine in the build photos is a 1275 A+, the engine in the first photo you posted is a different gold painted engine that personally I'm still not sure about either way but others might be. You will have to take more photos when you are next with it. But if someone sold you that engine telling you it was the one in the build photos then something isn't right.
Posted 18 May 2013 - 09:46 PM
Posted 18 May 2013 - 09:47 PM
Well spotted. The engine in the build pics is a 1275 A+, the ones the op has posted is also an A+, the ribs are a giveaway so it can only be a 998. It's a bit underhand to give the buyer pics of a different engine build that's painted the same
Posted 18 May 2013 - 09:48 PM
The engine in the second set of pictures dont have the same tappet chest covers and the one in pictures doesnt have a mechanical fuel pump, from what I can see anyway
Posted 18 May 2013 - 09:49 PM
