What Steering Boss?
4 replies to this topic
#1 IainNeon91
IainNeon91
  • 1,287 posts
Posted 19 May 2013 - 09:25 AM
Hi folks,
Just wondering, i have seen a few minis with these steering wheels now and i would love to have one of them.
Link: http://www.ebay.co.u...=item337fc945f2
But i have no idea what kind of boss you need to fit one,
Could anyone help?
Cheers,
Iain.
#2 Tupers
Tupers
  • 4,149 posts
Posted 19 May 2013 - 02:34 PM
MoMo 70mm PCD should do it.
#3 IainNeon91
IainNeon91
  • 1,287 posts
Posted 19 May 2013 - 03:37 PM
Cheers mate, i'll look into it.
Would any 70mm PCD boss work??
#4 IainNeon91
IainNeon91
  • 1,287 posts
Posted 19 May 2013 - 05:02 PM
Would either of these work/fit??
1st link: http://www.ebay.co.u...=item417168026a
2nd link: http://www.meanmachi...it-hub-kit.html
Many thanks,
Iain.
#5 Ethel
  • 25,954 posts
Posted 19 May 2013 - 05:18 PM
Not for a Mini, you need one that fits the Mini's column splines. I'll guess it is a Momo pattern too,as that'd give 36 to 37mm between hole centres.
Mountney M Series is likely to be the cheapest you'll find. Not to be confused with the original mountney which is bigger, 4 inch PCD (diameter between the 6 mounting hole centres.
http://www.meanmachi...it-hub-kit.html - cheapest google found, no idea if it's any good or not. Another factor is the fitting length, how far the combination of wheel and boss puts your fingers from the indicator stalk.
