Rev Counter Over Reading
13 replies to this topic
#1 mjpuds
mjpuds
  • 337 posts
Posted 19 May 2013 - 02:56 PM
Ok anyone know of the reason why rev counter reads x2 ...i know its something to do with coil wiring.. But what ..thats why im asking ...
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 May 2013 - 04:27 PM
?? what type of car and what ignition system ?? I'm guessing you have a mpi rev counter wired to a standard car where they read double
#3 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 19 May 2013 - 04:28 PM
have you fitted a (cream face) MPi rev counter?
#4 mjpuds
mjpuds
  • 337 posts
Posted 19 May 2013 - 04:39 PM
Sorry i have a cream faced counter...aldon yellow cap dizy .
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 19 May 2013 - 04:42 PM
Yup, chances are its an MPi one. I think speedy cables can recalibrate them but you bet it won't be cheap.......
#6 mjpuds
mjpuds
  • 337 posts
Posted 19 May 2013 - 05:00 PM
I thought before i had taken engine outit was normal..
#7 Lennyliverpool
Lennyliverpool
  • 329 posts
  • Local Club: northampton
Posted 19 May 2013 - 05:02 PM
I have the same issue - confused me at first  :ohno:
Now i just remember to divide by 2!! :proud:
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 May 2013 - 05:35 PM
  Because the MPi uses a distributorless wasted spark ignition.  This effectively means it has two coils, each one firing a pair of cylinders during each cycle.  The MPi tacho is only connected to one of these, so it expects to see a coil pulse only twice per revolution rather than four times.  When it sees four pulses, it counts two revolutions rather than one.  So it will read double when fitted to a conventional 4 cylinder system.
#9 mjpuds
mjpuds
  • 337 posts
Posted 20 May 2013 - 07:22 AM
When I say cream ... They are a fitted set of gauges that came in the walnut dash board ..think they are smiths...
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 May 2013 - 07:52 AM
  There is no other way for them to over read so much like this really (unless someone has messed with them), they must be MPi gauges.  Nippon Seiki rather than Smiths.  Do they have badges identifying the warning lamps or do they just have plain coloured lenses?  Smiths didn't make any magnolia faced triple gauge packs for the Mini and they were dropped as the manufacturer in 1988 I think.  If they are Smiths and have magnolia faces they must have been customised by someone so they may have been modified to work with a wasted spark system in the same way.
  Oh and the temperature gauge is probably not right either.
#11 mjpuds
mjpuds
  • 337 posts
Posted 20 May 2013 - 07:43 PM
Ok...not very handy then ..whats the best plan when using the walnut dash..
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 May 2013 - 07:51 PM
  Either get it re-calibrated or fit different gauges.  They aren't physically part of the dash and can be swapped for earlier ones.
#13 mjpuds
mjpuds
  • 337 posts
Posted 20 May 2013 - 07:58 PM
I have them out already..
#14 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 May 2013 - 09:12 PM
Speak to spedy cabes if you like the gauges http://www.speedycab...om/contact.html
