Mpi Power Boost Valve
5 replies to this topic
#1 chrisjenson1978
chrisjenson1978
  • 75 posts
Posted 19 May 2013 - 05:23 PM
hi there can any body help i have just bought a good second hand power boost valve and i have no idea how to fit as i dont have any instructions can any nice chap email a pic of there,s or give me a shout were to get instructions from etc etc
[email protected]
i have the valve with 3 ports i dont have a second little valve like on mini sport?? do i need this
http://www.minisport...VK384MGF1H.html
all the best chris
#2 jamesmpi
jamesmpi
  • 1,940 posts
Posted 20 May 2013 - 11:49 AM
Hello
First off you need to be careful how you set up the valve. It can ruin your emissions and fail the MOT if setup wrong.
If have one on my mpi. Don't have any photos to had but I made a bracket and mounted it on the LH side of the engine bay. I then had to make up some fuel line to run from the fuel rail to the boost valve and from the boost valve to the return pipe back to the fuel tank.
These websites may help
http://www.mgf.ultim...l_regulator.htm
http://www.v8engines...rboostvalve.pdf
#3 chrisjenson1978
chrisjenson1978
  • 75 posts
Posted 24 May 2013 - 11:58 AM
Many thanks for your email unfortunately emissions are crap any way as lambda sens is broke and its decatted lol but i will have a look it lso came with plenty of hoses can you tell me what goes were i.e. Top to say fuel rail side to etc regards
#4 chrisjenson1978
chrisjenson1978
  • 75 posts
Posted 24 May 2013 - 12:05 PM
Could you possible ring me ?? Regards chris
#5 jamesmpi
jamesmpi
  • 1,940 posts
Posted 24 May 2013 - 12:23 PM
If the lambda sensor is broken then I'm surprised your car runs at all as it needed for the ecu to adjust furling etc. lol
I will get some photos tomorrow as my car is kept away from my home and I can't remember which way round it goes.
The boost valve is marked with arrows showing direction of flow.
#6 samsfern
samsfern
  • 5,243 posts
Posted 24 May 2013 - 12:27 PM
Youll probably get a power boost if you fitted a new lambda sensor!
