Fitting Vaccum Gauge
7 replies to this topic
#1 biker1981
biker1981
  • Just Joined
  • 303 posts
Posted 19 May 2013 - 06:02 PM
iI ve just got a vacuum gauge that I want to fit. The thin diameter pipe that goes from the dizzy to the carb, the plastic pipe that fits on the dizzy has broke off.
Can I use larger diameter pipe off the dizzy and t piece it to the small pipe to the carb and big diameter to the guage if that makes sense :-)
#2 jpw1275
jpw1275
  • 2,803 posts
Posted 19 May 2013 - 06:04 PM
the vacuum gauge is normally plumbed into the manifold isnt it? i thought they went where the servo attached or similar if a servo is used
cheers james
#3 jpw1275
jpw1275
  • 2,803 posts
Posted 19 May 2013 - 06:06 PM
i mean inlet manifold not exhaust... just wanted to make that clear...;0)
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 May 2013 - 06:20 PM
  I don't think the vacuum used by the distributor for advance is what you want to be monitoring with a vacuum gauge.  As above the gauges usually monitor manifold depression while the distributor should be using throttle edge depression which isn't often the same.  In any case can you even get a tee-piece with different gauge connections on different outlets at this size?
#5 biker1981
biker1981
  • Just Joined
  • 303 posts
Posted 19 May 2013 - 08:45 PM
lol I'm still no wiser..... where I should be fitting in.  Where abouts on the manifold should I fit in please?
#6 The Otter
The Otter
    The artist formally known as j322overthetop
  • 620 posts
Posted 19 May 2013 - 08:56 PM
Assuming you have a standard fit HS4 carb, just buy one of these to replace your standard alloy carb spacer between the carb and inlet manifold.
http://www.minispare...FA338.aspx?1302
It has the built in vacuum line take off and is in the right place (i.e. after the throttle butterfly).
#7 jpw1275
jpw1275
  • 2,803 posts
Posted 19 May 2013 - 09:14 PM
yes as otter says.... i forgot about these spacers
#8 petehuws
petehuws
  • 329 posts
Posted 19 May 2013 - 09:28 PM
What Carb are you using?  The Otter has the best solution in buying one of those spacers with the vacuum take-off already there.
You can either drill into, tap, and then fit a screw in nipple for the vacuum hose directly into your inlet (REMOVE THE INLET FROM THE CAR BEFRE DRILLING, you don't want that alloy swarf to be pulled into your head), or again fit one of those ready made spacers.
I recently fitted a vacuum gauge into my car and went for one of those mini-spares spacers, works great!!
