New Hydrolastic Displacers
11 replies to this topic
#1 chicagoaustin1000
chicagoaustin1000
    Just On Tickover
  • 6 posts
Posted 21 May 2013 - 01:10 AM
Does anyone know if any vendors make new replacement hydrolastic displacers?  I have a right hand drive, 69 Austin mini 1000 and I live in the Chicago suburbs.
I have sourced two old used displacers from a junk yard (breaker yard?) in the UK, but would really like to renew all four displacers.  I have 70 series tires (tyres?) on the car and when the suspension collapses the tires end up sitting on the fender (wing?).
thanks,
Chicagoaustin1000
#2 rally515
rally515
  • 3,848 posts
Posted 21 May 2013 - 01:11 AM
should be able to ship them:  http://www.minimail.co.uk/parts/
#3 chicagoaustin1000
chicagoaustin1000
    Just On Tickover
  • 6 posts
Posted 26 May 2013 - 01:23 AM
thanks, I did not know anyone was producing them!
#4 rally515
rally515
  • 3,848 posts
Posted 26 May 2013 - 01:38 AM
Theres load here :lol: , everyone prefers "dry" because its less hassle so i guess thats why they price them so high
Cliff
#5 pdaykin
pdaykin
  • 587 posts
Posted 26 May 2013 - 07:33 AM
As far as I am aware no one is producing new hydro units. Only second hand are available - some types are effectively unavailable. The reason they are so expensive is that they have been out of production for many years
I converted to dry as I couldn't get matched sets for my Cooper S at a sensible cost - would have much preferred to keep the wet set up
Being second hand, some will be better than others
Edited by pdaykin, 26 May 2013 - 07:36 AM.
#6 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 26 May 2013 - 07:39 AM
thanks,
Chicagoaustin1000
I have a brand new pair, just one problem - i'm in Indonesia and they are in the UK, and I won't go back until July. If it's any use...PM
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 May 2013 - 08:38 PM
  No-one is producing them.  All are NOS or refurb and now at least 30 year old, age hardened rubber.  Better than nothing, but not as good as a new one would be.
#8 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 27 May 2013 - 03:26 AM
Yes, quite. These have been properly stored and outwardly show no signs of cracking and have never had fluid inside. Still, he won't need them now since refurb ones are available.
#9 pdaykin
pdaykin
  • 587 posts
Posted 27 May 2013 - 09:24 AM
If you do buy "refurbished" ones make sure you understand what you are getting
It often means just a coat of paint as they are pretty much unrepairable
#10 tiger99
tiger99
  • 8,584 posts
Posted 27 May 2013 - 04:30 PM
Yes, indeed how else could you refurbish such a thing? It is basically fraudulent. Remember that the actual spring medium is the rubber, the fluid only provides damping and load transfer to the other wheel, so they inevitably go the way of rubber cone springs, excessively hard, but finally disintegrating long after that.
I would suggest that all hydrolastic Minis will need a conversion to dry suspension sooner or later, unless someone does actually introduce genuine new displacers.
#11 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 27 May 2013 - 05:04 PM
Well I have a hydro car and the only thing I have had go is one pipe. I replaced it with another used displacer, but after seeing the car sat on its arches, I decided to fit a set of hyrdo competition bump stops, so if it ever goes again the car will sit on those. I guess the act as helps to the loads that the displacers would normally take.
I found that a rear ARB help the car but that was from the point of keeping the car flatter in corners and reducing the roll, but it also links the left and right together.
#12 62S
62S
  • 1,244 posts
  • Local Club: You must be joking!
Posted 30 May 2013 - 08:32 PM
You can have a new hose fitted.
