Brake Drum Stuck. How Do I Remove?
5 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 22 May 2013 - 09:03 AM
Hello
I am trying to remove the brake drum off my mini, and it wont budge. I have made sure the brake shoes are slackened off, and i've been hitting the drum with medium hammer blows (of course with wood in between to soften the blow). I have done this in all directions on the drum, including directly inward so at to try and dislodge it.
But no joy. The other three drums came off without a problem, but not this one. It is the offside front drum.
Could it be rusted to the driving flange? How can I best remove it?
John
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 22 May 2013 - 09:05 AM
If the adjusters are backed off, then using a lever between backplate and drum usually does the trick.Keep levering at opposite sides .
And keep hitting it..
#3 nickadees
nickadees
  • 44 posts
Posted 22 May 2013 - 09:12 AM
Try beating it with a copper/brass mallet rather than a hammer and a piece of wood, you will get more force into the hit without damaging the drum.
#4 mk=john
mk=john
  • 1,167 posts
Posted 22 May 2013 - 09:32 AM
I will have to get one of those hammers. Where can i get one?
#5 Ethel
  • 26,093 posts
Posted 22 May 2013 - 10:00 AM
Hit it towards the other front wheel on the edge so it levers away the oppososite edge, pivoting on the flange. You might also be able to wedge a thin screwdriver between the drum & flange.
#6 CobraV8
CobraV8
  • 991 posts
Posted 22 May 2013 - 10:02 AM
I find the hide hammers best, and you can give it a good whack
