I have a broken IAB connector with 2 cables red/blue wire and black.
The red/blue links to a blanked out part of the mini-tec connector (Do I need it?)
I don’t seem to have a knock sensor on the Vti engine harness. (is the yellow/white wire on the mini-tech connector what i need to wire into?) (I presume I need to install and wire up a knock sensor?)
Your help would be appreciated!
