Hi wonder if anyone can advise, driving my 1000 minivan home today and it wasn't firing right ,when I got home whipped the plugs out and numbers 1 and 4 were a perfect sandy colour but 2 was oily and three had carbon sooty deposit over it, the plugs were renewed only about 20 miles ago,after standing for about a year in the garage, I wire brushed them put them back in and it ran perfect for about 5 miles then the same thing happened , it doesn't burn oil and the engine oil level is fine ,I wonder if it can be valve related, it is the original leaded head , who sells unleaded recon heads ?any suggestions anyone? thanks ,Steve.
Van Plugs Fouling Up
Posted 22 May 2013 - 08:37 PM
Posted 22 May 2013 - 09:27 PM
is the needle valve and float level ok ? but as you say its a oily on 2 could be the valve stem oil seals or guides ? oil can only come in the guides or past the rings. do you see andy smoke going down hill on the over run. For it to happen in such a short mileage its something odd? 200miles but 20miles. Have you compression checked it?
Posted 22 May 2013 - 09:55 PM
swap the good and bad plugs, see if the problem persists in the same cyls or moves, ie dodgy plugs
Posted 23 May 2013 - 02:39 PM
I tested compression, all bores are between 130 and 135, I have put redex in the tank and I'll give it a bit of a run and see what happens ,there is never any smoke from the exhaust.
