The engine from the mini needs to go ASAP, the rest of the shell has gone, so will now be living outside until someone buys it! It was built, never run, still in the condition it came from the engine builders. It cost just shy of £5000 to build!
Spec:-
73.5mm bore, omega pistons
Lightened & balanced A+ conrods
Wedged, cross-drilled & balanced crankshaft
Pre-verto lightened & balanced flywheel
Grey diaphragm & rally bonded clutch plate
Piper 649+ camshaft
Lightened cam followers
MED 'S' management damper kit
MED alloy duplex vernier kit
MED billet oil filter head
Cooper s pressed rockers
SMMC breather system
SMMC offset cylinder head, 11 stud
Rim flow 37mm inlet valves, 31mm offset exhaust valves
240Ib valve springs, 3 angle valve seats
Bronze valve guides
Tran-x SCCR gear set
Mini sport centre oil pick up pipe
Minispares 4 pin differential
Straight cut drop gears 1:1
3.7 CWP
Collection from Oxfordshire
Offers will be listened too, £3500/offers
