Zero Compression At Cylinder 1
31 replies to this topic
#16 liam1288
liam1288
  • 602 posts
Posted 28 May 2013 - 03:28 PM
Ok so I reset the valves tappets and the car was driving fine afterwards! Went to York and back etc no problems but today on the way to hull just randomly as I put my foot down on the motorway it just got louder and not much speed increase along with the car shuddering... When I checked it at the roadside I checked the plugs and tappets again, one plug was loose so I tightened that back up but the valves seemed fine... So I drove on again and it was still shuddering etc!
I turned around and came back home, compression test is 12-13 on all 4. Checked the rotor arm which was black so I cleaned it up (running electronic ignition by the way)
What could be wrong now?
#17 lrostoke
lrostoke
  • 6,923 posts
Posted 28 May 2013 - 03:53 PM
was it raining
#18 liam1288
liam1288
  • 602 posts
Posted 28 May 2013 - 04:13 PM
Yeah but it's never affected it before since I've had electronic ignition
#19 liam1288
liam1288
  • 602 posts
Posted 28 May 2013 - 07:03 PM
Bump
#20 liam1288
liam1288
  • 602 posts
Posted 28 May 2013 - 11:30 PM
Yeah, they are all a nice biscuit brown colour
#21 liam1288
liam1288
  • 602 posts
Posted 28 May 2013 - 11:31 PM
#22 liam1288
liam1288
  • 602 posts
Posted 29 May 2013 - 12:09 AM
Well it's been sat for 7 months turned over a few times... The rotor arm just had carbon on I think. Ill check the pipes again tomorrow... Though revving it sounds fine its just then driving and I put the foot down so that eliminates air leak right?
#23 Yoda
Yoda
  • 1,958 posts
Posted 29 May 2013 - 05:47 AM
Any oil in the dash pot?
#24 liam1288
liam1288
  • 602 posts
Posted 29 May 2013 - 08:30 AM
Yeah there was but I topped it up when I did some checks
#25 liam1288
liam1288
  • 602 posts
Posted 29 May 2013 - 08:49 AM
Yeah I'd say it was dry carbon mate
#26 liam1288
liam1288
  • 602 posts
Posted 29 May 2013 - 10:11 AM
It's electronic ignition so there's no points or condenser
#27 lrostoke
lrostoke
  • 6,923 posts
Posted 29 May 2013 - 11:17 AM
If its got a dizzy it'll still have a rotor arm and dizzy cap which is what Dilligaf suggested checking/changing
#28 liam1288
liam1288
  • 602 posts
Posted 29 May 2013 - 12:29 PM
Correct but he also mentioned a spring so I just thought he meant points and cond
#29 lrostoke
lrostoke
  • 6,923 posts
Posted 29 May 2013 - 12:56 PM
No in the dizzy cap under the carbon pin in the middle is a spring...It keeps the electrode in contact with the rotor arm.
#30 liam1288
liam1288
  • 602 posts
Posted 29 May 2013 - 03:56 PM
Ahh! Sorry mate, no I've not looked! Ill check now :)
