I have a lot of panels that are now surplus to requirements. I'm based in Maidstone, Kent, and my preference would be for items to be collected.
Postage can be arranged if required, but a little patience will be needed, as this will be done through Hermes on a day that I can work from home.
Here's the list:
1 x Minispares flip front with grill cut out. Never used or even trial fitted. £120 (was £150 new)
Also, some metal panels (never used):
1 x pair outer sills (large) magnum - £5 each
1 x pair mk1 a panels with hinges and under scuttle corners minispares (14a8346/7) - £15 each
1 x pair mk1 a panels minispares (ms8r) - £5 each
1 x scuttle corner minispares ms6r - £5
1 x pair mk3 a panels hadrian - £5 each
1 x mk3 rear valence hadrian - £10
1 x lhs front floor panel hadrian - £10
1 x lhs rear floor panel hadrian - £15
3 x lhs flitch repair panels (2 magnum 1 hadrian) - £10 each
1 x rhs flitch hadrian - £10
1 x rhs door check panel magnum - £5
1 x rhs door check panel genuine (trial fitted but fine) - £10
1 x lhs door check panel genuine - £15
All of the below will be in these pictures:
