Morris Cooper Badge?
Posted 25 May 2013 - 08:11 PM
Posted 26 May 2013 - 07:41 AM
Posted 26 May 2013 - 10:56 AM
I'm pretty sure it's Morris as someone's just told me 68mm from the first hole to the second and the same from the 3rd to 4thAre you sure it isn't an Austin our mini minor spacing ?
Anyone know where I can get a genuine badge from?
Posted 27 May 2013 - 07:20 AM
http://www.minispare...px|Back to shop
Edited by mk1coopers, 27 May 2013 - 07:22 AM.
Posted 27 May 2013 - 09:49 AM
Just measured the 'centre line' distances between the pegs on the rear of my (genuine) Mk2 S badge, the two outer gaps are 68mm apart, the centre gap is 43mm.... so your bootlid definitely has Mk2 badge holes. Is it double skinned...? Late Mk1 and all Mk2* bootlids should be double skinned, with the 'ribbed' inner panel. If it is double skinned, yours could be from a Mk2 Mini 850 or 1000, or Mk2 Cooper 998 or Cooper 1275 S. It's worth rubbing down your bootlid to see if there are any holes under that filler on the r/hand side as Mk1 Coopers says.... the pegs on my '1275' badge are 57mm apart if that helps.
(* although some very late Mk2s had Mk3 bootlids, just to confuse matters!)
Edited by WMU 211G, 27 May 2013 - 09:51 AM.
Posted 27 May 2013 - 10:59 AM
Hi yep it's double skinned with the ribbed bits on the inside and the measurements you mentioned do match mine 68 and 43 so looks like I need a genuine mk2 badge I shall get on the hunt for one thanks for all you're help chaps it's most appreciated :)Just measured the 'centre line' distances between the pegs on the rear of my (genuine) Mk2 S badge, the two outer gaps are 68mm apart, the centre gap is 43mm.... so your bootlid definitely has Mk2 badge holes. Is it double skinned...? Late Mk1 and all Mk2* bootlids should be double skinned, with the 'ribbed' inner panel. If it is double skinned, yours could be from a Mk2 Mini 850 or 1000, or Mk2 Cooper 998 or Cooper 1275 S. It's worth rubbing down your bootlid to see if there are any holes under that filler on the r/hand side as Mk1 Coopers says.... the pegs on my '1275' badge are 57mm apart if that helps.
Posted 27 May 2013 - 01:03 PM
Minispares and Somerford do them - Somerford might still have some 'new old stock' plastic inserts with the embossed lettering etc ( later ones are the repro / printed sort)
##### DSCF5267 Dark Blue.jpg 46.07K
3 downloads
Posted 27 May 2013 - 02:21 PM
Summed up above better than I tried.
That'll teach me for not reading!
Edited by tomm, 27 May 2013 - 02:24 PM.
