Engine Making A Tinkling Sound
10 replies to this topic
#1 germini30
germini30
  • 722 posts
Posted 26 May 2013 - 08:18 PM
Noticed today in my mini that when pulling uphill if I put my foot down the car accelerates but I hear a tinkling kind of sound that then goes either if I ease back on the throttle or if the gradient becomes less steep. Is this sound pinking?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 26 May 2013 - 08:19 PM
Yes it is, you will need to sort that out sooner rather than later as you could be running too lean.
#3 germini30
germini30
  • 722 posts
Posted 26 May 2013 - 08:36 PM
The plugs are a golden brown colour. It's a 998cc.with a 12g295 head. I have 180psi compression across all four cylinders. Maybe its too high and trying to run like a diesel.
#4 sonikk4
sonikk4
  • 16,168 posts
  • Name: Neil
Posted 26 May 2013 - 08:38 PM
Has the engine been timed correctly and has anything else been done to the engine ie sports air filter modified exhaust etc.
#5 germini30
germini30
  • 722 posts
Posted 26 May 2013 - 08:40 PM
It's got a stage one kit with k&n element in nodded box. It's got megajolt but no rolling roads around here can tune it. I have the aldon yellow map loaded. Maybe go for a slightly more retarded map may help.
#6 sonikk4
sonikk4
  • 16,168 posts
  • Name: Neil
Posted 26 May 2013 - 08:41 PM
I think you have answered your own question there as the car really needs to be set up on a rolling road.
#7 germini30
germini30
  • 722 posts
Posted 26 May 2013 - 08:44 PM
Yes it does really but there are no rolling roads that understand megajolt around here. Think I will have to download a few maps and try the car until it feels right.
#8 germini30
germini30
  • 722 posts
Posted 26 May 2013 - 09:16 PM
Ok. Just take five degrees from every value? The car accelerates well on the flat or when only myself in the mini but with the wife and two children in it today I noticed the tinkling sound.
#9 germini30
germini30
  • 722 posts
Posted 27 May 2013 - 07:34 AM
Ok
#10 germini30
germini30
  • 722 posts
Posted 27 May 2013 - 07:46 AM
Will yet that later. 5 degrees should do it, it doesn't sound alot
#11 germini30
germini30
  • 722 posts
Posted 29 May 2013 - 06:02 PM
I have loaded the stage 3 1380 map onto the megajolt as it is lower by around 5-8 degrees over each value. Will try and see how it goes now.
