Please Help , Near Side Tail/side Light Fuse Keeps Blowing!
2 replies to this topic
#1 TommyWolstey
TommyWolstey
  • 31 posts
Posted 27 May 2013 - 07:24 PM
Hi guys , basically both of my left hand side lights weren't working aswell as the left tail.
I swapped the fuses but they kept blowing. I wired my front side light off the right hand side one and now that works as its being pulled off that circuit.
I thought that now I have relieved some load off the left side circuit it may help but still when I re fuse it and fire her up she keeps blowing. Anybody got any ideas ?
#2 TommyWolstey
TommyWolstey
  • 31 posts
Posted 27 May 2013 - 07:47 PM
Just an update if anybody reads this I've wired all of the sides off the right hand side tail light circuit and have fused it up to 20 amp just to get it through its mot then after that I think I will split the circuit and re wore one side to a spare way at the fuse box. Anybody see any issues with doing this?
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 27 May 2013 - 08:28 PM
Take the bulbs out and check if you have a circuit to earth on the n/s side light wiring and then disconnect the rear lamps from the loom and try again, seems like a circuit prob on the rear as the front o/s is now working ok. You could rewire it but check the loom carefully as it may be more problems if the wirings damaged somewhere.
Edited by KernowCooper, 27 May 2013 - 08:29 PM.
