Hs6 Su On 1100S Block / 12G940 Head
2 replies to this topic
#1 b80ven
b80ven
  • 39 posts
Posted 28 May 2013 - 05:49 AM
Hello all,
I have an issue with the setting of my HS6 on my 1275 cc engine.
I have been having startup issues and after working on it for 4 hours today trying to start it, I am quite frustrated.
Is anybody else out there running a 1 3/4" SU on their standard 1275 cc engine ? I am lead to believe the HS6 is not a standard Mini SU.
I'm familiar with adjusting the mixture while running by lifting the SU piston up (via the lever on the bottom), listening for an increase / decrease in revs, and reducing / increasing mixture as required. However, at start up, I'm after the initial settings for mixture, fast idle, and idle.
Mixture: I understand the bridge must be flush with the nut, when the case is removed. I have done this.
Fast idle / idle: Any ideas ?
The best my engine currently does is that it fires once, and cuts out.
I am contemplating changing the HS6 for a HS4 (single / twin - not sure), however, i'll leave this for another thread, I understand there are already quite a few threads on this topic.
B
#2 b80ven
b80ven
  • 39 posts
Posted 29 May 2013 - 09:05 AM
do you mean adjust the mixture 2 1/2 turns out from flush position ?
#3 b80ven
b80ven
  • 39 posts
Posted 29 May 2013 - 09:06 AM
I'll give it a go however I think the internals of my choke are stuffed.
Any ideas how to troubleshoot a damaged choke ?
