Hi all. Stripped my front subframe down this weekend and removed the hubs and noticed the bearings flop about in the hub about 5mm. Looks like smaller bearings have been dropped in, I'm assuming this isnt right and they should be a press fit.
Just wondered if anyone knew the outside dimension of the bearing, so I can check my hubs when I remove the old bearings.
Tried to get some part numbers off pictures online but haven had much joy.
Hopefully someone might know or have an old set lying around to do a quick measure for me.
Cheers.
