If your interested in anything on here PLEASE PM ME rather than posting on here or it will get unmanageable as I got quite a bit listed on here. Basically trying to move house so its got to go.
I'm open to offers for the lot! I have loads more stuff which isnt listed on here as well.
All parts are used but in good all round condition. Postage is not included and will range from £3.30 for small items to £6.99 for heavier items.
Oil filter housing - £10
Alternator brackets (A+) - £7
Rockers standard - £15
Forged Rockers - £30
Clutch / Flywheel assembly (Verto) - £35
Timing covers and Gears and chain without breather - £12.50
Starter Motor - Inertia - £15
Starter motor - Pre engaged - £25
Dipstick - £7
HT leads x4 - £5
Engine steady tie bars - £7
Gearbox case and diff housing - £45
All gears and cogs from above box - £25
or £60 for complete box in bits, was going to rebuild but never got round to it.
Radiator - been in garage for a few years had as a spare but never used it myself - £15
Radiator cowling - Solid and in good condition - One bolt snapped and will need removing, easy for someone with more time than me - £15
Engine block studs and nuts - £15 for complete set.
Chest covers and rubber seals - £10 for pair
998 pushrods - £10 for all 8
Dim Dip Relay - £10
SPI Accelerator Cable - £5
HIF 44 spares contact for more info on what you need.
HS4 abutment plate - £15
998 primary gear and transfer gear - £20
Speedo cable from 998 - £5
Water pump pulleys (various sizes and shapes small medium and large (SPI)) - £12.50
Crank Pulley (998 no damping wheel) - £15
Clutch Sleeve - £12.50
Distributor Drives A+ - £10
