Were To Mount Harnesses
6 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 28 May 2013 - 07:18 PM
To keep it short were else apart from the rear seat can I mount harnesses
Note I have no rear seats and will be fitting a 6 point cage but will have a small amp board in rear seat space
#2 Moggyton
Moggyton
  • 1,152 posts
  • Local Club: Stone mini club
Posted 28 May 2013 - 07:26 PM
You can get a harness bar?
#3 rally1380
rally1380
  • 1,893 posts
Posted 28 May 2013 - 07:35 PM
Harness bar is best as it gets the shoulder straps more at shoulder height rather than down low....which ain't ideal.
If you do mount low down, reinforce the fixing points with spreader plates.
Lap belts can be put in the standard fixings using eye bolts.
Plenty of info on this subject if you look for it.
#4 minilee94
minilee94
  • 3,523 posts
Posted 28 May 2013 - 08:10 PM
I should of noted before I can't fit a bar as I have got a board were my rear seat should be for my amp and sub and the board sits about 6 inches down from parcel shelf can I mount my harnesses at top of board wich will be sholder height going through the seat panel
If that makes sence thanks
If people have pics of the different ways of mounting harnesses will be great
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 May 2013 - 09:17 PM
  You will need to use a substantial amount of reinforcement to fit them to the top of the bulkhead, that and the parcel shelf are not strong.  Look in the boot of a Rover Cabrio for guidance.
#6 minilee94
minilee94
  • 3,523 posts
Posted 29 May 2013 - 07:08 AM
Okay thank you why will it not be strong ebough at the top but it is at the bottom
And what you mean rover cabrio
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 May 2013 - 06:54 PM
  The bottom is welded to the floor, and has reinforcing plates from the factory.  I have seen Minis at tracks pulled nearly inside out in a crash from the harnesses being fixed to the parcel shelf or top of the rear bulkhead.
  A Rover Mini Cabriolet.  It had the rear seat belts secured to the middle of the parcel shelf and a HUGE bracket in the boot to support them.
