Which Oil Pump?
6 replies to this topic
#1 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 29 May 2013 - 10:49 AM
hi just wondering if you could help, i have a 276 cam and an a+ block which oil pump drive do i need for this cam below
1B8D2EE5-8817-472C-A278-A96C63D5F85A-567
probably me being a retard but i don't think they do a triangle drive pump lol.
bear.
#2 mossy2a
mossy2a
  • 182 posts
Posted 29 May 2013 - 11:08 AM
The new oil pumps only come with slot or splie drive now.  I have a cam the same and had to make an adaptorlike the link below to use my cam.
http://www.spridgetm...-DRIVE-OIL-PUMP
#3 Cooperman
  • 23,513 posts
Posted 29 May 2013 - 11:10 AM
That is a spline/star cam and you need the correct drive pump, GLP141, and the adaptor fitting. These can be a bit hard to fine, but someone on here may have an adaptor.
#4 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 29 May 2013 - 11:17 AM
bugger anyone got one?
#5 mossy2a
mossy2a
  • 182 posts
Posted 29 May 2013 - 11:42 AM
There in the same place as the rocking horse poo etc etc..  Make one from plate.
I woulnt buy a GLP141 (its a spline drive), the adaptor plate only comes with a slot drive in it, as per my original link.
I spent hours looking for one and ended up making one from Stainless plate.
Edited by mossy2a, 29 May 2013 - 11:47 AM.
#6 Cooperman
  • 23,513 posts
Posted 29 May 2013 - 04:31 PM
The last time I did this I found the correct star-shaped adaptor which was standard for the original. Then I gave away the last one I had to a friend.
#7 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 29 May 2013 - 06:02 PM
crud, guess its a D.I.Y jobbie then
