First off, i know they have to be slightly different ( the bowl on left and right).. But if i could get hold of one of each, would i be able to make twins? i cant see why not, but i may be missing something. If i could, what would i need, throttle and choke linkage, is their anything else? thanks
Is It Possible To Make Twin Hs4's From Two Singles?
Posted 29 May 2013 - 06:29 PM
Posted 29 May 2013 - 06:39 PM
The 'other' carb on a twin SU set up is totally handed, its not just the bowl. Its a complete mirror image. If you used two 'singles' it would be difficult to fabricate a linkage to both chokes and throttles. Unless you found the other 'hand' carb as you say. otherwise there would be a whole carb in the way!
Edited by Algordo1100, 29 May 2013 - 06:40 PM.
Posted 29 May 2013 - 06:40 PM
The front and rear carb bodies are different castings. As said the linkage would be problematic.
Posted 29 May 2013 - 06:41 PM
It could be done providing the inlet manifold could be modded to get the clearance and you can fabricate the new linkages ect...
2 HS4's is slightly overkill any way...
Posted 29 May 2013 - 07:31 PM
I have one from a 70 race car, didnt beleive it till i saw it
