hi, just wondering if anybody can shed some light on how the MD 286 cam drives and feels like? also what the idle is like.
thanks in advance, bear.
Edited by brad-the-bear, 29 May 2013 - 07:19 PM.
Posted 29 May 2013 - 07:19 PM
Posted 29 May 2013 - 07:28 PM
Posted 29 May 2013 - 07:29 PM
Been covered to death here on the Forum, search will reveal all just depends on what you want to use the car for and how often you want to pull the engine apart for a rebuild.
have a look at the other posts Brad
Posted 29 May 2013 - 07:36 PM
Posted 29 May 2013 - 07:42 PM
Posted 29 May 2013 - 07:52 PM
The 276 is a nice cam. Pulls well from a very useable 3000rpm and tops out at around 5000rpm in torque and 6000rpm in power. It's suitable for town driving, but the idle will be lumpy below 900-1000 rpm, obviously depending on other factors, too.
The choice ultimately probably depends on how you will be using the car.
I have personally only ever taken the engine past 6000rpm for more than a few seconds on the track, so a powerband that only really starts there would be pretty useless to me.
Posted 29 May 2013 - 08:02 PM
Posted 29 May 2013 - 08:03 PM
Posted 29 May 2013 - 08:06 PM
Have you driven the 276 you have?
If yes, do you think it's boring yourself, or are you just bothered by its bad reputation by "the people"?
If no, why not give it a try, if you have it already?
Posted 29 May 2013 - 08:12 PM
Posted 29 May 2013 - 08:13 PM
Posted 29 May 2013 - 08:18 PM
ive had a 286, you really do need to rev it, it will be loud, high revving etc.
Ive had a 276 in a 1293cc engine and that drove very nice, didnt have the punch of the 286 so to speak but certainly was matched for pull upto 5000rpm.
Im using a KC800 in my 1293cc, stage 3 head with double valve springs and it drives really nice. I need it tuning on a rolling road, hopefully get that done in June.
Posted 29 May 2013 - 08:26 PM
Posted 29 May 2013 - 08:27 PM
Another cam to throw into the mix is the more modern profile Swiftune SW-10 cam. http://www.swiftune....t-camshaft.aspx
Their website also shows an example dyno graph for the cam.
It is their version of the Kent 286. It's machined by Kent, it is more suited to road use, it has a flatter power profile and it has better on idle emissions and wear characteristics than the 286.
The SW-10 is the cam that Peter Vickers recommended and used to build my Engine hence why I am showing bias towards this particular cam.
Posted 29 May 2013 - 08:35 PM
Was going to mention Swiftunes offerings....get great reviews.
I think essentially what Brad wants (sorry to hi-jack here) to know, is which cam is best to fit in his new engine for road rally use?
