Sorry guys i bet you're sick of these types of posts by now but my 1996 Rover Mini Sprite 1.3 SPI is having trouble passing the emissions test. Initially it was failing being high on the CO reading and the Lambda reading but is now only failing the CO reading of about 1.5% fast idle.
Since it originally failed the MOT on emissions i have changed the cat converter (REACT cat converter), lambda sensor (bosch), air filter, all vacuum pipes & elbows, engine oil,spark plugs, oil filter, adjusted the tappets, Inlet air temperature control valve in the air filter is working correctly, the temperature gauge rises to the middle N position not long after starting and remains there as normal so can therefore rule out the CTS. This collectively has brought the tick over of the car down from about 1000 rpm idle to a steady 850 rpm idle and the car has never sounded as good! However after taking it for a retest it failed only on the CO reading of 1.5%, lambda and HC were bang on ok. I've also had this further confirmed at another mot station to rule out a badly calibrated reader. The old spark plugs were all sutty and black with the news ones ive put in are showing a pale brownish grey colour.
I have been informed, whether correctly or not, that the ECU may require either resetting or fault codes removing. Can anyone confirm if this is correct and could now be the cause of my problem? If this is the case is there anyone out there who has a code reader they would be willing to lend me? I would collect it in person, leave whatever deposit and guarantee its safe return. I live on Merseyside and will be willing to travel within 50 mile radius.
As my car is now on SORN and has been off the road for over a month down to this problem i am desperate for any help, i have ran out of ideas and would really appreciate input from someone with a bit more experience.
Thanks.
Edited by Cass0, 30 May 2013 - 11:39 PM.
