Mini Sprite Losing Power Then Overheated
5 replies to this topic
#1 Simmondsp
Simmondsp
    Starting My Mini Up
  • 3 posts
Posted 31 May 2013 - 07:30 PM
Hello everyone. New to this forum and to the mini. I just purchased a mini sprite 1300 auto. I have been driving it around and went for a longer than usual journey for the car (25 miles). I was going up an average hill and the mini all of a sudden started lacking power. After this I noticed that the temp gauge had started to rise. I stopped the car just before it went on red and after I stopped I got outbid the car to then hear a burst of water come out from the bottom of the radiator (where the sensor for the fan is)
Anyone have any ideas before i jump in and break more! Annoyingly I was going to take it to Brighton this sat for the show!
#2 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 31 May 2013 - 11:40 PM
I'd say it was leaking coolant.  :-)
The root cause could be head gasket failure.
Why not open the bonnet and take a look.
#3 Simmondsp
Simmondsp
    Starting My Mini Up
  • 3 posts
Posted 01 June 2013 - 08:19 AM
Cheers man. Another thought would be that. It was leaking coolant and a small amount of water has been sucked into the air box? That would temporarily cause the mini to lose power wouldn't it?
#4 Gulfclubby
Gulfclubby
    Gulf Boy
  • 751 posts
  • Name: Ben
  • Local Club: Berner Mini Club
Posted 01 June 2013 - 08:49 AM
Very unlikely. More likely a head gasket problem as was said. Of course there could be a ton of other problems too.
You really need to look under the hood and see what's going on, or have someone have a look.
How's it running otherwise?
#5 Simmondsp
Simmondsp
    Starting My Mini Up
  • 3 posts
Posted 03 June 2013 - 12:27 PM
I got is sorted in the end. The plastic clip that keeps the aux fax switch connected to the radiator was missing. so as i was driving it the water was going everywhere in my car and up the intake. then when i had stopped the fan switch flew out from pressure. I changed the fan switch and put the plastic clip in and its working fine now.
It got me to Brighton and back to Dartford yesterday! Ill have it in for a good check over this weekend though.Exhaust is blowing and i have a very minor oil leak too.
any advice on common places to check?
#6 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 03 June 2013 - 02:28 PM
take the front wheels off(one at a time if you don't have a ramp) check subframe mountings(for corrosion on the bodyshell) and rubbers(on the mounting plates in the front footwells)
tightness check top arm pin nuts, top ball joint, trackrod end(bj nut), bottom arm, balljoint and tie bar (both ends)
