Acrylic Laquer Help Please
6 replies to this topic
#1 mk1steve
mk1steve
  • 12 posts
Posted 02 June 2013 - 09:56 AM
Hi all.
Urgent help required.
I;ve spent 3 months doing the prep work.. wont bore you with details but the usual sanding / filling / sanding etc etc.
Got it quite good now, infact real good I think!
I have bought Acrylic Laquer paint as doing it in the garage.  I;ve today painted the interior, boot, engine bay and arches.  Tomorrow I plan to paint the outside.
The colour is tartan red / black roof.  I'll do the roof in a week or so after masking car off.
My questions is this :
I've read that I can put 5-6 coats on with sufficient flash off time inbetween..  then leave it a week or more before flatting back with wet and dry before buffing.
Other places I have read you should put on about 3 coats then leave for about 3 days before flatting bach with about 400 grit and applying another 3 coats..  then perhaps even doing that process again after 3-4 days.
So which is it?  Can I do it in one carefull hit with nice flash off inbetween coats or do I have to do it the drawn out way?
I put 3 coats on the boot, interior and engine bay. I think this will be OK as I don't intend on flatting back much.
thanks in advance
Steve
#2 Daz1968
Daz1968
  • 2,058 posts
Posted 02 June 2013 - 03:03 PM
Look up the spec sheet for paint on manufacturers website, it should explain number of coats and flash off time between, but I would aim to just put all required top coats on same day, then leave to harden then flat and polish about a week later.
I know the acrylic paint I looked at was just 2 coats, first light and second full wet. I am still undecided if I am using acrylic or cellulose.
#3 mk1steve
mk1steve
  • 12 posts
Posted 02 June 2013 - 08:36 PM
Thanks for the reply.  I would have thought 2 coats not enough? When you cut it back and buff you would think it would be not enough paint on there.   If you are putting clear coats on the top I guess it would be OK.
hmm, decisions..
#4 mk1steve
mk1steve
  • 12 posts
Posted 03 June 2013 - 04:03 AM
Well.  Today was the big day.  I decided to see how the first few coats went on then decide.  To my delight it went on very nice so I kept going.  I lost count but pretty sure I put 7 coats on.
I left 15 mins between coats and about half way through left it 30 mins.   I thinned it 1 part paint to 1.5 parts thinners and the last 2 coats went closer to 1 part paint to 3 parts thinners.
I'm very happy with the results.  Will leave it a few days and mask the car to paint the roof black.
I then intend on assembling the car again and wet and dry / buff up at the end
#5 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 03 June 2013 - 05:34 AM
easier to wet / dry and buff without the car assembled in my experience, but sometimes time is a factor.
I havent done this to my green mini yet and it was painted sept 2012....due to time.
#6 mk1steve
mk1steve
  • 12 posts
Posted 04 June 2013 - 04:51 AM
Its a tricky one. I know what you are saying but its off to a mechanics house to help me with engine re fitting, subframes etc etc.. It will be there a number of weeks and the potential to scratch the freshly buffed up paint work is high.
Also, I understand its good to leave it a while before cutting back and buffing to allow all the solvents to come out of the paint.
Tonight and tomorrow i'll finish sanding the roof and then paint that black.
#7 SAL 821X
SAL 821X
  • 1,890 posts
Posted 04 June 2013 - 02:58 PM
Sounds like your doing it the right way.
A picture speaks a thousand words though.
Giza look see.
