This is partly developed twin throttle body set up for the a-series. its still needs some work to complete as sold as seen/incomplete. sat on the shelf in the garage for years. was going on a mini project but i sold the car years ago. my current mini runs a vauxhall lump and its unlikely i'll be getting another a -series engined car again.
its basically a pair of individual tapered bike throttle bodies split down, which handily take a standard rover mini fuel injector. a basic manifold has been fabricated (not port matched)...just a quick mock up but works. it has separate fuel rails so you just need to tap one side to thread in a barbed hose tail for rail inlet/outlet and make up a pipe to connect the two bosses via the outlets on the top
you'll also need to extend the linkages between the TB's. TPS already fitted
£90
cheers
matt
Edited by maph2, 03 June 2013 - 09:58 AM.
