Hey guys,
how do i tell what size HiF carb i have without stripping the air filter etc off it?
what size should be on a 1994 1275? cheers
Posted 03 June 2013 - 03:02 PM
Hey guys,
Posted 03 June 2013 - 03:05 PM
Original fitment would be an HIF38 which will see you up to around 80bhp without restriction and if you are handy with a dremmel then you can take the flow up enough to handle 85+.
If it hasn't got the little metal tag one it with the number then then only defining way is to remove it and measure the throat.
Posted 03 June 2013 - 03:06 PM
it does have said tin tag, 2 minutes till i go find it,, what numbers do i need to look for?!
Posted 03 June 2013 - 03:09 PM
okay i have the tag,
the codes are
MAC10031
WK 04 94
Posted 03 June 2013 - 03:11 PM
The whole number ideally, it's not very long.
Type it into google and it should give you the answer, I can't find the bleeding site or I'd link it ![]()
Posted 03 June 2013 - 03:12 PM
Posted 03 June 2013 - 03:14 PM
thanks a million fella
Posted 03 June 2013 - 03:15 PM
No worries.
