Whining Noise From Carb/intake Manifold Area
5 replies to this topic
#1 liampalfrey
liampalfrey
    Starting My Mini Up
  • 3 posts
Posted 03 June 2013 - 05:38 PM
Any help would be appreciated, recently a whining noise has started from the carb/intake manifold area at the back of the engine, seemed to stop temporarily with a bit of WD40 but now it's pretty much constant.
The noise is pretty high pitched and only seems to stop during acceleration which made London to Brighton traffic a nightmare haha
Any help or pointers would be greatly appreciated as I have no clue!
#2 sledgehammer
sledgehammer
  • 3,104 posts
Posted 03 June 2013 - 06:34 PM
check inlet manifold nuts are tight - a slight tweak may change the noise -
if they are tight then  a new manifold gasket
or a pipe cracked / come off
Edited by sledgehammer, 03 June 2013 - 06:36 PM.
#3 johnnyblaze
johnnyblaze
  • 189 posts
Posted 03 June 2013 - 06:46 PM
yehp air leak there sumwhere, get the car running then spray little squirts of wd40 around the place you did before when it stopped, if it should increase the engine revs then remedy the problem, loose bolts or pipe issue or gasket blown out or somthing
#4 liampalfrey
liampalfrey
    Starting My Mini Up
  • 3 posts
Posted 22 June 2013 - 11:32 PM
problem solved as of now, so far so good anyway! used some instant gasket around the top of the inlet manifold and havent heard a single noise since!
#5 sledgehammer
sledgehammer
  • 3,104 posts
Posted 23 June 2013 - 10:18 AM
Glad you solved it temporally
I would still buy a manifold gasket ,
#6 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 23 June 2013 - 10:36 AM
Second that ^
