Hi,
I'm in the process of putting a new head on. I'm wondering if it's necessary to use new head studs, or if the old ones are ok to be reused.
Thanks!
Posted 03 June 2013 - 11:38 PM
Hi,
Thanks!
Posted 03 June 2013 - 11:55 PM
You can reuse them.
Posted 04 June 2013 - 05:31 AM
^^^^^What she said.
Posted 04 June 2013 - 06:08 AM
Last time I did ours I removed them all and ran them over with the wirebrush in the drill just to clean out the threads and generally clean up.
Posted 04 June 2013 - 11:49 AM
Brilliant, cheers guys.
Posted 04 June 2013 - 12:17 PM
Posted 04 June 2013 - 12:48 PM
Tap 'em with a spanner when the head is off.....make sure they don't sound dull.
Posted 04 June 2013 - 12:50 PM
^sensible^
One advantage of having an ancient, all cast iron, engine is holding it together is less problematic, though the A+ fasteners are more sophisticated then the pre A+ ones if you have the choice.
