hey guys , i started my car up last night and on tick over fuel was coming out the overflow :S , now its a pretty fresh rebuild specs are: 1275 , stage 3 head , 276 kent cam , hif 44 with k and n and a stub stack on a mini spares inlet and a bdk needle i think , it been running fine before had it started up for 5 or more times before , but started doing it last night
Posted 04 June 2013 - 08:56 AM
Posted 04 June 2013 - 09:21 AM
you running any sort of filter, could be dirt in the float needle
Posted 04 June 2013 - 09:37 AM
or bang the carb with a big screwdriver handle... might shake the dirt from the needle. I once did it in a hurry in a mini outing to help a stranded mate - it worked!
Sure enough I advised him to look at the carb when he got home!
Edited by klivins, 04 June 2013 - 09:37 AM.
Posted 04 June 2013 - 10:06 AM
ive got a inline filter just out of the fuel tank but the carb had been stud a while , cheers guys will give it a strip down later
Mini Technical Sections →
Problems, Questions and Technical →
Hif44 Starter Spindle Seal Fitment IssueStarted by JimmyStinkpickle , 21 May 2026 |
Help Pls! Engine Not Starting, Not Sure What To Do!Started by TheYoungestGary , 08 May 2026 |
Overbored Or Supercharged 850 Rebuild?Started by kkonstantinopoulos , 04 May 2026 |
Su Hs4 CarburettorStarted by Murrayup , 21 Apr 2026 |
Missing Speedo Drive Clamp PlateStarted by JimmyStinkpickle , 18 Apr 2026 |
