I have a 93 mayfair when i put the headlights on the side comes on but so does the h4 bulb dim dip its called in the manual but is there a way of just having the side light only i have just bought some drl headlights and they would look better with just the leds illuminated. Is there a relay i can take out? any ideas
Side Lights Dim Dip Is There A Way Of Side Light Only
Posted 04 June 2013 - 01:05 PM
Posted 06 June 2013 - 07:35 AM
Unplug the resistor.
Stood in front of the car with the bonnet raised. On the right hand side of the engine bay you'll see a gold coloured ribbed cylinder. It's usually bolted vertically to the stay between the tower mount/bulkhead crossmember and the inner wing. Trace the wire from it and you'll find a round plug/socket. Disconnect that and seal the ends - the end that goes into the wiring loom will have a live wire when it's trying to do it's dim-dip stuff so you need to make sure noting gets in there that could cause a short and you also want to avoid rubbish getting in there so that it'll work if you come to re-connect at a later date.
Not sure if the location of the relay is different on a wrong hand drive car.
Iain
Posted 06 June 2013 - 08:38 AM
