Spi Battery Charging Fault
Posted 05 June 2013 - 10:28 PM
Posted 06 June 2013 - 02:40 PM
What is your actual fault? A flat battery or just the fact its showing 11.34 Volts? Sorry got to start somewhere.
Posted 06 June 2013 - 06:37 PM
Posted 07 June 2013 - 01:45 PM
Posted 07 June 2013 - 05:13 PM
Posted 08 June 2013 - 02:07 PM
I've checked the other connections on the alternator and they're fine. The battery warning lamp comes on with ignition and goes straight out as soon as the engine fires up.
Does anyone think it could be the voltage stabiliser behind the dash as the above link says?
Posted 08 June 2013 - 10:22 PM
The warning lamp is working as it should so, it is unlikely that there is a problem with the instruments. I would remove and clean all the earth connections starting with the battery to body. Then I would add a second earth wire from the clutch cover to the body earth point by the body diagonal brace between the servo and the inner wing.
If that does not fix it, the positive battery cable could be suspect. But before replacing it, check with the engine running the voltage from an earth point to the alternator output and then at the connection to the starter coming from the alternator the brown/purple wires. If they have a poor or no connection, the car would start but the battery would no charge since basically the alternator output is disconnected from the battery.
Posted 10 June 2013 - 06:28 AM
It sounds similar to a problem I created by changing the warning light for an LED as being a diode it prevents the current in one direction so that the rotor cannot be charged up. Just in case you have done anything similar
Posted 10 June 2013 - 12:18 PM
The more I think a bout it, the two brown/purple wires from the alternator might be the problem. They connect to the starter using a single fusible link and it might be fused.
