Im gonna do my tower bush's tomorrow and aint got a 1"5/16th socket, so is a 33mm socket ok to use or does it have to be spot on with the imperial?
Posted 06 June 2013 - 07:02 PM
Posted 06 June 2013 - 07:04 PM
Worth doing it with a 1"5/16th socket as that converts to just over 33mm, so you'd have to use a 34mm socket which is slightly over sized and then you run the risk of rounding it off.
Worth having as a 1"5/16th is also the hub nut.
You can order it as TOOL04 from Mini Spares.
Edited by Noah, 06 June 2013 - 07:05 PM.
Posted 06 June 2013 - 07:06 PM
yea i thought i had a imperial socket, as iv done my CV joints last year, but cant find the thing..grrr
EDIT: I would but need one for tomorrow, and Halfrauds aint got one
Edited by Ipod, 06 June 2013 - 07:19 PM.
Posted 06 June 2013 - 07:21 PM
Try Machine Mart, if you have one locally. Or any motor factors/tool shop.
Posted 06 June 2013 - 07:36 PM
Any motor factors should be able to get you one fairly sharpish. Laser tools part number: 0925
Posted 06 June 2013 - 11:25 PM
34mm Single hex would be OK...the correct sized imperial would be better.
Posted 07 June 2013 - 12:47 AM
If you buy, get a deep one (like Minispares's), it'll fit all possible uses.
