The Importance Of Lock Tabs! Please Read!
9 replies to this topic
#1 ejs-1995
ejs-1995
  • 108 posts
Posted 08 June 2013 - 06:39 AM
Hi all, I just wanted to make a quick post to stress the importance of correctly using a lock tab washer.I recently changed my clutch on my mini and afterwards had a whole host of problems and noises. I had torqued up the flywheel retaining bolt but re used a tired lock tab washer. Anyway, to cut a long story short the other day my engine locked up when I was trying to start it. I removed the bell housing to find this, a loose flywheel bolt!!!! The lock tab washer had totally flattened! This doesn't just apply to the flywheel, ANY bolt that needs a lock tab washer should have one and if you have any doubts about the washer, REPLACE IT!!!!! I sure have learnt my lesson
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 June 2013 - 07:00 AM
Or use Loctite.
#3 ejs-1995
ejs-1995
  • 108 posts
Posted 08 June 2013 - 07:19 AM
Or use both
Edited by ejs-1995, 08 June 2013 - 07:19 AM.
#4 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 08 June 2013 - 08:24 AM
I wonder if these new lock tabs are a little soft? I now use a thread compound.
#5 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 08 June 2013 - 08:32 AM
Where are they made?
#6 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 08 June 2013 - 08:33 AM
Who knows? I do know the last one I had in my hand felt very cheap? It went in the bin,
#7 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 08 June 2013 - 09:15 AM
The lock tab is actually floored engineering. I fit these bolts without the soft lock tab. Use a thread locker and no tab, tighten to 140lbft and you will never have a problem.
In herently the lock tabs are soft. The tab then crushes under the load of the bolt. The pressure is then released on the bolt. The bolt comes loose. Modern cars use flange bolts for 2 reasons. Cheaper to produce ie no lock tab and more reliability.
Ac
Edited by ACDodd, 08 June 2013 - 09:16 AM.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 June 2013 - 09:20 AM
People ask why I don't use locktabs in gearboxes...
AC has so eloquently put it above that I need say no more.
#9 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 08 June 2013 - 05:25 PM
Cheers!!
AC
#10 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 09 June 2013 - 03:40 AM
Uhm, people forget that washers have material standards too.
