Oil
Posted 09 June 2013 - 02:31 PM
Posted 09 June 2013 - 02:35 PM
You really need to stop the leaks as when the Halfords oil is warm it thins down. The recommended oil for mini's is 20W50 anyway.
Posted 09 June 2013 - 02:43 PM
Posted 09 June 2013 - 02:45 PM
Posted 09 June 2013 - 06:15 PM
A thicker oil won't stop leaks. You need to identify the cause of the leaks and rectify them.
Posted 09 June 2013 - 09:33 PM
Dont want no "whacky racer" oil slick...
Posted 09 June 2013 - 09:38 PM
Posted 09 June 2013 - 09:41 PM
Posted 09 June 2013 - 09:54 PM
Either that or somethings cracked!i got 10 points on a gasket
Posted 09 June 2013 - 10:02 PM
Posted 20 July 2013 - 03:34 PM
I have the same problem, did you manage to fix it?
Posted 20 July 2013 - 03:38 PM
Sort the leaks, GTX is far better than the halfrauds one
Posted 20 July 2013 - 03:44 PM
Posted 20 July 2013 - 03:54 PM
Oils with same hot viscosity index are supposed to have the same viscosity once at temp.
Apart from that Halfruads' shears down way before the GTX, acting like 40 weight oil once warm..
Posted 20 July 2013 - 03:58 PM
