Rear Inertia Seat Belts ?
11 replies to this topic
#1 majorj0nny
majorj0nny
  • 176 posts
Posted 09 June 2013 - 07:31 PM
I'm sick of the standard massively long belts ... Does anywhere do an inertia belt kit ? Otherwise can I fit a set of fronts in the back ?
#2 Tupers
Tupers
  • 4,173 posts
Posted 09 June 2013 - 07:52 PM
Latter MPI minis ('96 onwards) had inertia belts in the back, I'd look for someone breaking one.
#3 minimaxie
minimaxie
  • 1,687 posts
Posted 09 June 2013 - 07:57 PM
Try PM'n Dale on here under username R1minimagic. He breaks n sells MPi parts
Edited by minimaxie, 09 June 2013 - 07:58 PM.
#4 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 09 June 2013 - 08:23 PM
Some of the later spis had them (my 1995 does) so may be worth looking
#5 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 09 June 2013 - 10:13 PM
Securon 257 will fit the rear and are retractable, I've got one fitted to mine. :)
#6 majorj0nny
majorj0nny
  • 176 posts
Posted 14 June 2013 - 11:39 AM
thanks for the replies guys .
my mini is a 1990 model and has 3 point static belts.
will inertia belts just mount on there shoulder point as a straight swap or will I need to strengthen the mounting points in any way ?
#7 majorj0nny
majorj0nny
  • 176 posts
Posted 16 June 2013 - 08:36 PM
257 ? I can't find that... Will the 254 do ?
Can I take it any adjustable angle generic inertia belt that mounted to the b post will do ?
Surely if the car has an existing 3 point static belt in the back I can just do a direct replacement with a suitable inertia belt ? Someone suggested I need to strengthen the parcel shelf ?
#8 A-Cell
A-Cell
  • 1,610 posts
Posted 16 June 2013 - 08:47 PM
Contact Somerford Mini with the exact details of your car. Get some modern and therefore you know safe (not been in an accident and stretched) and working mechanism.
See item 24
http://www.somerford...age=page&id=137
#9 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 16 June 2013 - 08:48 PM
Parcel shelf? I mounted mine to the original top mount point, which is already tough as.
My bad, you're spot on. It's a 254 not 257 but I was close! :P
I'd suspect that any adjustable angle belt should fit the bill, yes. But at £30 I went with a new one I knew would fit.
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 16 June 2013 - 08:54 PM
  In my experience Securon belts are garbage.  In a daily they last 2 years before they wear out, I've had loads but will not be getting any more.  Get belts made to your specification, or buy off the shelf, from FDTS in West Byfleet for around the same price as Securon.  Incidentally, the guy who owns Securon gets his special order stuff and other custom work made by FDTS too.
#11 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 16 June 2013 - 09:00 PM
Mine should be fine then, I take a passenger in the back about once every 4 months. At 2 year life for daily use that means I won't need to replace it for about 243 years :lol:
#12 majorj0nny
majorj0nny
  • 176 posts
Posted 17 June 2013 - 11:19 AM
lol - thanks for the tips guys ..
