Will This Be Safe For A Harness Bar
16 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 10 June 2013 - 09:51 PM
Right the red bits in the picture are the mount points with spreader plates this is what the mounts are made out of
Durable: High corrosion resistance, Hot Dipped Galvanised Cast Iron to BS EN ISO 1461:1999
Green bits is just a scaffold or similar bar will be used once set in right position all joins can be welded
Do you guys think this is safe thanks lee
Can't fit harness bar as I have a roll cage
Edited by minilee94, 10 June 2013 - 09:52 PM.
#2 Turbo Nick
Turbo Nick
  • 2,913 posts
Posted 10 June 2013 - 10:13 PM
Erm?! surely you need a cage to fit said harness bar?
Harness bar without a cage is just asking to end in tears imo.
#3 minilee94
minilee94
  • 3,523 posts
Posted 10 June 2013 - 10:14 PM
I have got a roll cage but the mounting brackets for a harness bar go we're the cage mounts so it won't fit
#4 Tupers
Tupers
  • 4,160 posts
Posted 10 June 2013 - 10:22 PM
I'd PM JonsBetts and see if he can make you a harness bar similar to his original style ones. Clicky
Also I don't know what cage you have but Safety Devices make a harness bar that bolts onto their cages.
#5 petey81
petey81
  • 1,346 posts
Posted 10 June 2013 - 10:24 PM
just as I was going to suggest.
#6 Tupers
Tupers
  • 4,160 posts
Posted 10 June 2013 - 10:26 PM
/\ Great minds.  :lol: /\
#7 minilee94
minilee94
  • 3,523 posts
But they won't fit as the cage mounts sit were there meant to sit il message him and ask but I don't think it will be a win
Obv not fitted propley yet but you get what I mean
Edited by minilee94, 10 June 2013 - 10:28 PM.
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 June 2013 - 10:30 PM
  Cast iron is not really suitable for mounting a seatbelt.  It's not ductile but very brittle, it snaps without warning when overloaded.
#9 Tupers
Tupers
  • 4,160 posts
Posted 10 June 2013 - 10:31 PM
How about one of these welded to each rear leg of your cage with a removable harness bar between them? Clicky
It's something best tackled by an experienced welder though. You really shouldn't use the seat back to mount the harness bar, it's not nearly strong enough.
#10 minilee94
minilee94
  • 3,523 posts
Posted 10 June 2013 - 10:34 PM
Okay thank you for that dan
#11 minilee94
minilee94
  • 3,523 posts
Posted 10 June 2013 - 10:36 PM
Oi I am a good welder thanks tupers lol
And I wanted to avoid any welding as I have new carpets etc in the car
#12 Globule
Globule
  • 1,134 posts
Posted 10 June 2013 - 10:37 PM
Seconded, if you look at their door bar kits, it has all the adaptors etc to fit inside their tube so you don't have to weld it on if you didn't want, i'm not sure on the safety aspect of that though.
#13 minilee94
minilee94
  • 3,523 posts
Posted 10 June 2013 - 10:39 PM
I'd PM JonsBetts and see if he can make you a harness bar similar to his original style ones. Clickymini222.jpg Also I don't know what cage you have but Safety Devices make a harness bar that bolts onto their cages.
My cage I a Huddersfield spares one an yeah iv seen there one but no way in a million years I'm paying nearly £200 of it if I can make something that does same job
#14 Midas Mk1
Midas Mk1
  • 5,796 posts
  • Local Club: S.U.N.M.C
Posted 10 June 2013 - 11:01 PM
If you dont want to weld, have you already welded in the reinforcing brackets/spreader plates for the cage?
Edited by Midas Mk1, 10 June 2013 - 11:01 PM.
#15 iTomKart
iTomKart
  • 351 posts
Posted 10 June 2013 - 11:18 PM
Forgot who makes them, but I've seen harness bars that bolt/weld to the side of the wheel arch rather than the top so you can still fit a roll cage. Might be worth looking into
