Newbie Looking At A Vtec K20 Zcar Build. A Few Questions For Pros !
Posted 12 June 2013 - 12:19 PM
1. If I was to find a Honda ep3r wreck ( with assumed running gear / wiring etc) would this be a good step towards the build ? IE use the wiring loom , ecu etc ?
2. What size rims are needed to clear the rear disc brakes ?
3. Would cooper 7.5 inch discs be sufficient for the front ?
Thanks !
Posted 12 June 2013 - 07:46 PM
if you buy a wrecked EP3 for the right money, then u could use all the parts you need. ie engine, box, ecu, wiring, etc and sell on the rest of the car and make some money back
zcars mini run on 13
thanks
john
Posted 19 June 2013 - 05:27 AM
thanks
john
Defintiely trying to source this ! I thought id ask a few more questions - as zcars seem to reply once a month !
1. What budget front brakes do people suggest to use ? Can i use a metro turbo setup ? (8.5s ?)
2. Anyone know the fuel tank capacity of the FRONT replacement kit from zcars ?
Thanks !!!
