Hi I am shortly moving into a unit where im going to restore my mini. It needs lots of work to the floor pan so I was going to put it on its side as I have the space but what I ned to know is.. Do I roll it as a bare shell or would it be easier to do it if the wheels are still on then remove the subframes. Any help or personal experience appreciated thanks david
Putting Shell On Its Side
Posted 12 June 2013 - 06:34 PM
Posted 12 June 2013 - 06:48 PM
I've been advised not to roll shells onto their sides, a lot of force is exerted through the side panel, a/b/c pillars and when all the weight is put over them they can easily warp/change shape. bending the side of your car , I would definitely think about reinforcing your car internally before even thinking about rolling onto it's side.
People will probably jump in here and shoot me down saying they have rolled shells over hundreds of times without problem, I am only sharing what I have been told.
Posted 12 June 2013 - 06:51 PM
Don't worry ive thought about the bracing issue. I currently have a web of box section that puts my mates race car roll cage to shame. it will also be going onto a mattress to protect the outer panels
Posted 12 June 2013 - 06:53 PM
if you have a completely bare shell and your floors and sills arent extremely rotten the i found it was fine, just get several tyres to spread the weight as much as possible
as archa said, it would be better to brace just in case though, i only needs to do several patches on my floor and the rest was very solid
Posted 12 June 2013 - 06:56 PM
yep also started my collection of tyres so far got 9 10x5's. Thanks for the advice
Posted 12 June 2013 - 06:57 PM
then it sounds like your sorted
Posted 12 June 2013 - 07:02 PM
just got to agree the unit and get moved in then :)
Posted 12 June 2013 - 07:03 PM
thanks gremlin.. how many people do you reckon it will take to lift it. Its a clubman estate.
Posted 12 June 2013 - 07:10 PM
3 people can lift a shell no problem, me and my friend could lift and roll my shell with no problem which was a standard shell
Posted 12 June 2013 - 07:11 PM
When I put my shell on its side, I strapped 6"x6" timber lengths to the front and rear body seams top to bottom using bungee cords with old pillows between the body and the wood. Then I got some help tipping it over. This way the weight was on the seams keeping the door and quarter panel off of the floor preventing damage to them.
The other benefit to this is that the shell stood better without wobbling about and there was no flammable mattress to catch fire.
Hope this helps
Ben
Posted 12 June 2013 - 07:18 PM
ok thanks
Posted 12 June 2013 - 07:36 PM
Posted 12 June 2013 - 07:53 PM
Mine is on its side with engine in it. Ratchet strapped in to protect mounts. 2 Of us flipped it over.
Posted 12 June 2013 - 09:12 PM
Rolled my clubby estate onto a matress as a bare shell, no problems with any warping and I just used me and a jack. Take the subframes off first though.
