Got a bit of an issue here, hoping some of you much better qualified than me can help make a decision on!
I recently had my Mini serviced at a local(ish) Mini specialist, who is regarded as a bit of a guru with all things Mini.
I questioned him about the open breathers (arrowed "A" in the pic) and he advised to leave as they are.
However, a couple of people commented on this on the recent Scottish Thistle Run, and stated they should be connected to the breather cans coming from the timing chain case and clutch housing respectively, otherwise she will run like a dog. (The thing is, she can be a bit temperamental at times - and smoky under load, but I thought this was just a Mini "thing") Are these guys right, and this is the reason for the occasional coughing, or should I be listening to the local Mini Meister?
The second issue is the tube marked "B". What is this, and should it be connected to anything? It looks like its been capped, (by the Mini specialist) and once again some of the lads on the run commented on this...
Thanks as always in advance!!
