So Wishing I Had Balanced Flywheel To Crank
12 replies to this topic
#1 mjpuds
mjpuds
  • 337 posts
Posted 15 June 2013 - 12:32 AM
as heading says just built up engine 1380 been running it in over last month all done now ..but i ran out of time and fitted my old flywheel from my last build...so wish i had balanced flywheel to crank..i am thinking there is a little to much vibration..for my liking ..anyone else had issues like this..
#2 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 15 June 2013 - 12:55 AM
The whole lot should ideally be balanced as an assembly. If you fit a flywheel from an assembly that has already been played with, that flywheel could be all over the place in terms of balance.
#3 mjpuds
mjpuds
  • 337 posts
Posted 15 June 2013 - 11:13 AM
Bit late now...bugger
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 June 2013 - 11:24 AM
How much vibration do you have ? there are lots of 1380s running standard out and about not balanced, what sort of revs is it at? I had my 1330
flywheel.crank and clutch done as a unit.
If you not revving it to death and it does not feel smooth in normal driving you have a problem somewhere.
#5 mjpuds
mjpuds
  • 337 posts
Posted 15 June 2013 - 12:21 PM
more than my last engine but that had a softer cam ..276..this has a 286.. 1.5 rockers .. when revs kick in it smooths out a bit ..but with nothing to base it next to it tricky..
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 15 June 2013 - 12:25 PM
are we talking vibration due to unbalence?
or vibration, due to higher idle / lumpy idle caused by the cam (286). Whats your idle speed?
#7 jaydee
jaydee
  • 8,565 posts
Posted 15 June 2013 - 02:35 PM
you should feel it vibrating at about 3k rpm if not correctly balanced
#8 Cooperman
  • 23,513 posts
Posted 15 June 2013 - 03:16 PM
With a 286 you will be needing to use around 6700 rpm to get the best driving performance and a full rotating assembly balance is absolutely vital.
#9 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 16 June 2013 - 01:29 AM
From what I understand, the 1275 crank will resonate at between 5950 and 6250 rpm......obviously there are sub harmonics too.
#10 jaydee
jaydee
  • 8,565 posts
Posted 16 June 2013 - 11:10 AM
Thats why it resonates at 3k rpm...
#11 mjpuds
mjpuds
  • 337 posts
Posted 16 June 2013 - 02:32 PM
Now heres a question if I bought a lets say med or similar ligthened balanced flywheel backplate and cover ..and swapped it over would a lightweight kit make this less noticeable. .
#12 Cooperman
  • 23,513 posts
Posted 16 June 2013 - 07:04 PM
Not really. The bottom end must be balanced as a unit or it will not be balanced at all.
If running a 286 with the rev range necessary to make it worthwhile fitting it, then a full balance is essential.
#13 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 17 June 2013 - 02:49 AM
Thankyou - I'd never managed to work that out.
Balance and resonance are two different things though, as I'm sure you know.
