Replace Cam Follower's?
Best Answer Captain Mainwaring , 18 June 2013 - 12:29 AM
If they don't show any signs of spalling or cracking and aren't dished then put 'em back....if they do, then the cam is probably not 100% either, might be worth replacing it too while it's all apart.
Go to the full post
9 replies to this topic
#1 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 16 June 2013 - 08:08 PM
hi, just a quick question,
am in the process of an engine build and i am reusing the cam (MD276). as the original followers are already settled to the cam should i use the old ones or can i replace them?
cheers
bear
#2 robba_duck
robba_duck
  • 326 posts
  • Local Club: looking for a new one
Posted 16 June 2013 - 08:28 PM
Use NEW ones
The followers take a lot abuse and wear quickly, New ones are cheap so why reuse.
That's what I think anyway.
Rob
#3 A-Cell
A-Cell
  • 1,610 posts
Posted 16 June 2013 - 08:30 PM
Yes fit new ones.
#4 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 16 June 2013 - 08:50 PM
cheers guy's
:D
#5 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 17 June 2013 - 03:12 AM
I'm not sure I'd fit new followers to an old cam either (unless I had to)
I think unless they were flaked, cracked or pitted then i'd either leave them or fit new followers with a new cam.
#6 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 17 June 2013 - 06:01 PM
this is what bugged me, i heard new followers to an old cam can cause premature wear on the cam lobes.
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 17 June 2013 - 06:43 PM
How many miles has the cam/follers done as a pair? I would use them again if low mileage as they would be worn to the lobe thats if you have them numbered and matched to a lobe, if you dont have them numbered fit new, but if they had covered 50k miles I'd fit a new cam and folowers
#8 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 17 June 2013 - 10:08 PM
got the followers and they are all numbered, but i don't know what mileage they have done.
#9 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 18 June 2013 - 12:29 AM   Best Answer
#10 jaydee
jaydee
  • 8,565 posts
Posted 18 June 2013 - 08:30 AM
You dont keep them if you havent take note of their number and same applies to the pushrods
